Should the battery be in Pro 2 camera if I intend to run it using electricity via the USB?
Should the battery be in the camera if I intend to run it using electricity via the USB?
It will work either way. Arlo suggests leaving the battery in - which will keep the camera running if there are any power glitches (including someone accidentally pulling out the cable or charger). They say it won't over-charge if you do that.
