Should the battery be in Pro 2 camera if I intend to run it using electricity via the USB?
  • 1 Reply
  • 753 Views
lidbit
Should the battery be in the camera if I intend to run it using electricity via the USB?
It will work either way.  Arlo suggests leaving the battery in - which will keep the camera running if there are any power glitches (including someone accidentally pulling out the cable or charger).  They say it won't over-charge if you do that.
  • 1 Reply
  • 754 Views
