I've been leaving the Base connected & turned on 24\7. Should I turn the Base off when cameras are off?
Thank you. IlI' leave the base on.
I can’t think of why you’d need to do that. I suspect that would be pretty unusual among Arlo owners. Also, when the cameras are “off”, they are really just “disarmed” and awaiting instructions. I suspect the cameras still communicate with the base from time to time even when they are disarmed. They are only “off” when there is no battery installed and/or no other power source like a wall outlet or solar panel.
You are very welcome.
NO... do not.
Just disarm the cameras and they go into a low powered sleep mode.
If you turn off the base, the cameras will drain the batteries in a fairly short time looking for the base unit. ( sort of like a cell phone without service ) The base and cameras ping each other now and then.
