Edge is ending support for Adobe Flash Player
  • 14 Replies
  • 4451 Views
  • 2 Likes
  • 9 In Conversation
wallys3d
I keep seeing a message in  Microsoft Edge browser that adobe flash player will no longer be used in 2020 what will i have to do in order to use my browser to check on my Home while away ?
Thank-you
JessicaP
With Flash Player support becoming obsolete in the very near future, we’re happy to announce that as of May 1st, we’ve transitioned away from Flash Player and it will no longer be needed to live stream Arlo Cameras when using a web browser.
Adobe Flash Player is still required if you have a continuous video recording (CVR) subscription plan. We plan to transition away from Flash Player for CVR users in a release later this month.
14 REPLIES 14
Guessing by then, Arlo will have made a change ( it's prob in the works now ),
or use a diff browser ( or mobile app )
wallys3d
Thank-you TomMac for  the reply
A_P
Arlo needs a viable PC client well before flash support ends permanently, a Microsoft Store app would seem ideal rsther than Netgear continue to have to try to support multiple browsers and/or force Arlo users to work in specific browsers.
For example, Windows arm tablets running Firefox arm already can't use Arlo due no Flash support and still no Windows app from Netgear.
If you could please pass this problem to Management and post their response, that would be helpful for those considering buying Arlo or moving away from Arlo for these reasons.
https://www.theverge.com/2017/7/25/16026236/adobe-flash-end-of-support-2020
michaelkenward
Sensei Sensei
Sensei
You should also add this suggestion to the  Arlo Idea Exchange - Arlo Communities.
Just another user
TaylorM
Flash is being discontinued on all browsers. Adobe's no longer supporting Flash starting in 2020, so they will have to do something. I hope they make an announcement soon. It barely works as is.
A1_most-Done
How do you get a problem resolved if Support cannot give you appropriate assistance?  I have explained that the Flash is active and included [selected] in my browser.  What is the next step to get someone's attention to the "LIVE" view problem on the PC to get it resolved?  Again, no problem with IOS access.   Please H E L P ! ! !    The following is the most recent response from Arlo Support which is of not use since I use Internet Explorer 11 -- not Google Chrome.   Also, tried Google Chrome, and problem still exist there as well ! ! !
Subject: Unable to view the live streaming from 21st
Case Update
KB article: https://kb.arlo.com/000062077/How-to-troubleshoot-Arlo-web-client-Flash-errors-when-using-Google-Chr...
To send a follow-up response, please click on the “Update Case” button below.
Did you unblock flash for the site in Chrome as explained in the kb article? If you did, then the issue isn't with flash.
wallys3d
i ask my question 4 months ago, i do not understand what your reply has to do with my question,most likely it does not
just mark my question as unsolvable, and i will not attempt any other questions. ridiculous
I was replying to A1_most-Done (and assumed that TomMac had answered your question to your satisfication).
Flash is being deprecated by Adobe, and will be removed from web browsers at the end of next year (December 2020).  Arlo is well aware of that, and their CEO has said (in a tweet) that they will transition to html5 before that happens.  Like everyone else here, I hope that transition happens sooner rather than later.
So you will still be able to use the browser after flash is removed (and in fact it should be easier, since there will be no need to unblock flash when you use the web client).
But in the meantime, you do need to unblock flash.  That's not difficult in edge, though it is a bit tedious to have to do it over and over.  If you do need help on how to do the unblocking, please do reply and we can provide the steps.
michaelkenward
Sensei Sensei
Sensei
As @StephenB says, other people have joined in the discussion since you lobbed it in some months ago. "Hijacking" discussions is supposed to be against community the rules, but that does not stop people from piling in, often with questions that have little to do with the original.
I'm afraid there is no "unsolvable" flag, which is not in any case true. Arlo has just decided not to solve it yet. But if you want to bring the discussion to a halt then marking it as Solved might at least deter latecomers for sustaining the agony.
Just another user
John_Mastro
According to the new version of Edge, Microsoft will no longer support Flash Player after December 2020. Does anybody know what Arlo plans on doing with this? Without flash one cannot view their camera's from a PC.
Thanks!
Thanks!
They've announced that they will switch to html5 before the browsers drop support for flash.
John_Mastro
Thank you!
JessicaP
  • 14 Replies
  • 4452 Views
  • 2 Likes
  • 9 In Conversation
