Security camera and Starlink
  • 6794 Views
OhioFarmgirl
Our Starlink router has no where to connect our camera cable - is there a work around for this??
I believe you can get an ethernet accessory from Starlink.
Another option is to get a wifi extender with ethernet out, and pair that to the starlink wifi.  Then connect the base to the extender ethernet.
lyman1903
using Pro cameras,   and Starlink,
starlink set up to not have a password,  open connection, and ARLO will not scan the Qcode,
laptop and phone have no issues,  connection wise,
The install for Pro, Pro 2, and Pro 3 models doesn't scan a QR code.  So you must have a Pro 4 or a Pro 5s that you are trying to install.  Which do you have?
Arlo requires a WPA2(AES) encrypted network (with a password).  Once the install is complete and any firmware updates are applied to the camera, it should be able to use WPA3.  But you will still need a network with a password.
  • 6795 Views
