The cameras all work, but when I click on "Live" I get a pop-up in the middle of the camera screen that says Adobe Flash Player Settings, Local Storage, Allow my.arlo.com to store information on the computer?
Can that box be removed?
When using the Chrome browser everything works fine.
Thanks.
Everything seems to be working fine now.
Thanks for everyones comments 😉
These messages are signs that your browser is trying to protect you from "dangerous" content. Many browsers throw up the same dire warnings. You will have to find out how to give your browser permission to run Flash.
Some browser are more forgiving than others. Some will remember the settings, others require a fresh tweak every time you launch them.
It won't be long before Flash goes to the great code writer in the sky and just won't work. There are alternatives, but Arlo seems to be determined to sit on its hands and to keep Flash going until the last possible minute, sometime in 2020.
Maybe this will help:
Enable Adobe Flash Player for Safari
Here's what you do for some other browsers:
How to troubleshoot Arlo web client Flash errors when using Google Chrome
Cannot view Live Feeds - Flash problem AGAIN! - Arlo Communities
Just another user
michaelkenward is is correct. I'm running 10.15.2 and Safari gave me a one time dialog to allow flash and Safari has been working with complaint.
I think all you have to do is click ok or allow one time. Arlo won't use flash to install something bad on your computer.
