srim,
You can still view these videos by navigating to the library and filtering for the desired camera. All the content for each camera is still present in the library.
Hi, I just started using the new ARLO iphone app. When you click on Devices and see each of your cameras, there are no badges under each camera you can click on to see the videos it has recorded. When you get a new video, you will see a badge with a number 1, but once you have viewed that video, there is no badge with a zero in it like there used to be that you could click on and see previous videos that you had already watched.
Did you use the library tab? Make sure no filters are set or set them for whatever cameras you need.
Do you mean nothing in the library or no library tab?
srim,
