Remote motion triggers for Arlo Pro 2 since motion detection doesn't work through glass
This system needs to have the availability of remote triggers since motion detection is not available through the Glass...
At $220 a pop-- simply mounting outside is not a great otpion as they are easily knocked down or neutralized. Having a less expensive trigger remotely turning on a camera that is Hardwired with power indoors, inside a window makes this product much more effective and usable. the Motion relays would also be less conspicuous and much nicer for those with strict HOA rules ..
Half way to sending this back for a refund....
The Q cameras detect motion well through glass.
