Recordings no longer saved
Recordings are no longer saved locally on my base. I have saved recordings on base for years, using USB memory. I have checked the USB memory stick is visible and have reset it to free up space. But regardless I still get an error that ‘videos stored on base station are not available’. What do I do?
Are you sure this is a recording problem? (not a playback problem)?
Did you check for recordings on the USB stick on a PC to be sure?
Did you reformat it using the App? Or in a PC?
Do you have another USB stick you can try (at least 16 GB)?
