  • 2 Replies
  • 989 Views
Passion593
Changed my internet provider and my arlo will not reconnect
Which base model... do you mean the 3500 or 4500 ?
no 9500 model.
michaelkenward
Sensei Sensei
Sensei
You have a new network. You need to set it up afresh. This means resetting and adding everything in the chain.
Be sure to restart your network in this sequence:
  • Turn off and unplug the modem (if there is one).
  • Turn off the router and computers.
  • Plug in the modem and turn it on. Wait 2 minutes.
  • Turn on the router and wait 2 minutes.
  • Turn on computers.
  • Add Arlo hub to the router as per the setup procedure
If the rest of your network is already working, just restart everything in the right order and then add the hub.
If that doesn't work, come back with more details. We know next to nothing about your setup
Just another user
  • 2 Replies
  • 990 Views
