Hi guys
Need help for some reason 2 of my cameras don’t work properly once plugged into power both on CVR plan but don’t work properly the recording pretty much is on and off every few seconds repeatedly! But when I pull the power they both work perfectly via wifi no glitches but can’t use CVR subscription without power?
It’s doing my head in and I’m about to throw everything in the bin please help!!
You can not use the CVR plan unless the cameras are powered...
Also, the cameras still are motion detect to trigger a recording which will appear in the library and should be a part of the CVR ( but an underline in color ) on time line.
Are you using Arlo power supplies ?
@TomMac So one of the cameras is plugged in now without CVR subscription shows blue light and is working fine on wifi but obviously no CVR
As soon as I re subscribe and CVR attached this is where the problem is! It has something to do with the Arlo cloud??
It may be... contact Arlo support
That's funny, my two cameras running on ac work fine. My problem is with the battery powered ones, which with a paid subscription to Arlo Smart Premier, are suppose to provide me with the activity zones. These zones are totally inactive, and I am paying for the service. Waiting on Arlo on this "known issue" as reported by them. And waiting, and waiting.....
i have yet again for about the 7th time cancelled and resubscribed to cvr still no change , I have included a screenshot of my timeline to explain the on/off recording??????
