Pro2 camera fails at naming step
I saw that this is supposedly fixed
- I had to reset one of my camera. Cannot add it back it hangs at naming
It appears to connect (fast flashing blue light)
Which basestation are you connecting it to?
I have an Arlo 2 Pro camera and it will not get past the naming stage. I have seen the solution to reset the Basin re-add all of the cameras but not only is that cumbersome given the location of my cameras but I don't trust arlo will work with any cameras after that I'd rather lose one camera and keep the other five then risk losing all the cameras. #trust
Which basestation are you onboarding them to?
