Pro 2 offline
  • 4 Replies
  • 2343 Views
ronbuck1
Pro2 offline
reboot base with power button
check battery
etc
Kind of hard to help when you send so little info about issue
@ronbuck1 wrote:
Pro2 offline
Maybe tell us more, so we can actually help.
  • All cameras, or just one?
  • Have you checked the base station LEDs
  • Have you checked that the camera is charged?
  • Have you tried restarting the camera (remove/reinsert the batteries)?
  • Have you tried power-cycling the base?
ronbuck1
Maybe you misunderstood the problem. How do I reboot or bring system back on line from a distance when one body is home.
You can't remotely reboot the base if it is offline already
Two future solutions;
1) a UPS to base for short time power outages
2) a WEMO unit that plugs into the ac outlet ( base power plugs into it ) and if there is wifi, the wemo outlet can be remotely toggled off-on ( which usu resets the base )
  • 4 Replies
  • 2343 Views
