Pro 2 camera won't connect to VMB4000r3 base
Well, system (app) updated and moving camera, it will not re connect. I am highly frustrated. These worked fine when swapping with the earlier app. The cameras are good, but the app is garbage. Base VMB4000r3, Pro 2 cameras, on Windows ten or on Pixel 8. I tried everything suggested in search of posts, still won't connect.
Message 1 of 2
306
Hi @jtannenba
Are yo still experiencing this symptom? Did you remove the camera from the app or physically around your location?
Message 2 of 2
271
