Pro 2 brightness does not make any visible change
Has there been any updates to the terrible night time vision on the Pro 2s?
One of them is now inside, and no matter what brightness level I set it to, during dusk it does not change. During the day time on same setting it's almost completely whited out.
Attached is a pic of the Pro 2 inside, near windows as you can see and brightness set to 75-100% makes no visible changes.
I previously had a Pro 1 in this same exact spot and did not have this issue.
Try moving the camera a little so that the windows are not showing up. It could be that the white balance of the camera is getting fooled by the bright light coming in from the window.
Brian
