Pro 2 How Do I add My Husbands Phone
  • 1 Reply
  • 1354 Views
LeaNoraC
I need help syncing my Husbands phone to cameras. Mine did fine, but can not get his onboard. Can you sync to more than 1 phone?
Yes but not in the way you're thinking. Use Settings, Grant Access to his email address. Be sure to add the additional access privileges if desired. Follow the emailed directions carefully. That way both of you can log in at the same time using different credentials and check things out.
  • 1 Reply
  • 1355 Views
