Retired_Member
Not applicable
2019-09-22
04:49 PM
I've just setup my Arlo security cameras and am finding that I'm getting more notifications than I want. The issue I'm seeing is in modes there doesn't seem to be a way to set notification per camera. I would like all of my cameras to record if they detect motion so that if something ever happens I can look back at the video later. But I only want to be notified if a couple of my cameras trigger, not for all of them. Am I missing something or is there any way to do this? Push notification send to be globally on or off in each mode, not for each camera.
Message 1 of 3
3,101
Yes you can do it. Under modes you can have one rule per camera to trigger recording. For each rule you can enable or disable push and email notifications.
https://kb.arlo.com/1019297/How-do-I-set-up-notifications-or-alerts
Retired_Member
Not applicable
2019-09-22
09:20 PM
Thank you. That did it. On iOS it exits after you hit Save for your first rule so I didn't realize you could go back in and make a second rule.
Message 3 of 3
3,086
