PIR lens damage by woodpecker. What can I use to replace the lens?
I have 2 Pro 2 cameras (That still work) and both have the PIR lens destroyed by a woodpecker. The Len's are completed broken up and shredded. What can I use to replace the lens?
Thanks for any direction to a solution!
All you can try is to use the Contact Support link at the bottom here to see if they can/will do anything. If not, it's a new camera purchase (or use another camera to trigger this one in your modes and rules).
