Error message when trying to log in. Occurred first on I Phone, than next day on both my IPads. I have only had this system for a month. Not sure how to fix. I deleted the app and reinstalled it but has not worked.
Also some times it will go to the Enter Verification code, but it does not send me a code.
Hey Nopp,
Do you have two-step verification enabled on your account? If you do, try to disable it and re-enable it to see if that helps.
