Have 2 Arlo Pro cameras that appear to be working just fine. However in checking the library, I can see that one of the two is not saving any recordings to the Cloud. The other is. Thoughts??
Assuming you using armed mode, check the arm mode rules include the missing camera.
And make sure there's no filter set in the library that would prevent you from seeing all cameras.
