One of my Arlo Pro 2 camera just stopped working. Blinks but won't sync. Tried replacing.
I have 5 Arlo Pro 2 cams. A few months ago we had one camera just up and quit. Blue light on when plugged in, blinks when you try and sync, but won’t ever sync. And I’ve tried multiple times. If I unplug it from the charging cable it will not even allow you to try and sync, appears to be completely dead even though it been plugged in and charging. I considered it a fluke and just replaced the camera. Now I have a second one do the exact same thing. I’ve had the set up less than a year. Not very cost efficient if I’m going to keep loosing cameras like this. Any suggestions?
Why are you buying new cameras when you have a warranty? Use the Contact Support link at the bottom here.
