One camera is not automatically recording when sensing motion. Will record if I manually go live. Other camera working fine. Base station showing both cameras are paired. Was previously working fine , not sure what has changed. Restarted base station to no avail.
please assist. Thank you.
Thank you , I've managed to fix the problem by removing the battery from the camera, removing the device from the system and then setting it up again.
Read this elsewhere on forums.
its all go again.
Have just used motion detection function to test this and there is no light flashing in response to motion. What now?
Verify that the camera is armed. The motion detection icon in the Devices tab should be black, not gray.
its all go again.
Frustrated. Since one of my cameras stopped recording recently too. This is a pain.
Yep , Im still good here.
No idea what caused it.
Good luck
