							One camera keeps recording audio even when it's switched off. And don't trigger movements.
1. We have 4 cameras and 1 keeps on recording Audio even with it switched off.
2. Then the cameras also dont trigger all movements. I leave for work with my car but it does not record that.
1) Did you disable audio detection in your modes and rules?
2) Positioning and sensitivity settings are key. Post screenshots of affected cameras for suggestions. Read the FAQ here on best camera positioning. Make sure motion is mostly side to side and not directly to/from the camera. Try increasing sensitivity in your modes and rules.
						Arlo Mobile App629
						Arlo Pro 211
						Arlo Smart180
						Before You Buy996
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,322
