One Camera Is Appearing Offline
I had synced up all cameras before I went on line now it is only showing one of the four cameras on the online acct.
How do I start over? or do I have to start over.
Following directions included with the system is always a Good Idea.
You can try syncing the cameras normally again by briefly pressing the base sync button - don't hold it - and then the camera sync button If that doesn't work, remove all devices in Settings, My Devices and start fresh. Claim the base and then sync the cameras.
