One Arlo Pro 2 Camera is not always recording
Hi Team,
Out of the cameras I have there is one which is not always recording.
Are recordings based on the strength of the wifi connection?
Having said this I can manually record.
Please advise.
Thanks in advance.
Recording isn't based on signal strength although that does have an effect (weak signals may cause corruption in the video). Have you checked your modes and rules to verify the proper mode is selected and it has a rule for the camera? You may need to remove and resync the camera.
