Notification if camera goes offline?
  • 1 Reply
  • 2821 Views
  • 2 Likes
robbiebrown34
Hi
Is it possible to get a notification when a camera goes offline?
I had an issue a few days ago where a camera on CVR (with battery in) went offline and wouldnt come back on unless I removed the battery (which is fine), however it was at the beginning of the evening and I didn't realise until the following morning - thus giving me a 12 hour black hole.
Nothing happened fortunately - but it could've!
I suspect the answer is no, having had a read around. But I thought I'd ask in case they've added it into a new update.
Can't be that difficult to setup a ping to the camera and if it doesnt respond, send a notification!?
Rob
R
As you suspected, the answer is no.
  • 1 Reply
  • 2821 Views
  • 2 Likes
