Not recording
One of my cameras are not recording. The others are. Anybody experience this issue? What is the cause and fix?
This is a pro 2?
Can you make a manual recording while livestreaming the camera?
Yes I can record manually
Good, that means that the camera does have cloud storage.
Next try the motion detection test for the camera. The steps are in this article:
I changed motion sensitivity and it still does not work. It only records when it picks up sound.
You're saying the motion test does not work? That implies a faulty camera. If you're editing the camera rule in your modes with motion detection enabled, that's not necessarily the same thing.
