Ac power has been disconnected from your Arlo device.Activity zones are currently disabled. and a red circle with a ! in it shows on both the Arlo pro and the Arlo pro 2. We checked and they are online and the power is NOT OFF. Any idea whats wrong?
Made font size smaller on phone. After you punch the OK a dozen times, the camera comes up. As soon as you close the app, it reverts back. Of course, everything on my phine is now too small to see. This is BS
A new version of the Arlo mobile app is available form the app store that resolves this issue. Please make sure your Arlo mobile app is updated to the latest version available.
Arlo Android App - 2.21.2 - 19th October 2020
If you're still experiencing this issue, please start a new thread here on the community and let us know the details.
Thank you,
I am getting a message on the App, AC Power has been disconnected from your Arlo Divice, Activity zones are currently disabled. i have checked and every thing seems ok ????. what has gone wrong, and the fonts seem to have gone larger, i have
Mostly its Samsung offices having this issue on the android app.
Thank you
The above suddenly appeared on all my four camera displays. Won't even let me push the green "OK" button! I've uninstalled and reinstalled the App, still the same is happening. Android Huewei P20 Pro phone being used for a year with no problems. Help please. Regards Dave.
**This is an update to my previous post regarding the same issue. Arlo has updated my case and informed me to update the app now through the play store and the issue is resolved and I'm confirming that it does seem good to go now from following those steps. Cheers.
Hi there,
Did you get this issue ever solved? We have the same problem now since the latest firmware update. I uninstalled the App already twice, deleted the cache, but nothing helped to get rid of those messages. They come back on all device screens.
I am sure it has something to do with the firmware update, that happened on 16. Oct, because that is when the issue started. We have two systems and the Apps for both systems run on Samsung Cellphones/Android.
Any help would be appreciated.
Thanks.
But yes I wanted to give you all an update, and let you know it went away.
Not really sure after if all our gripes and complaints was the reason or the fact that I kept uninstalling the Arlo app several times and reinstalling it did the trick but I am happy to say it is gone. I didn't really do anything at all that I hadn't tried before.
So needless to say it is gone. Hope yalls are working properly now as well.
Take care.
I was getting the error message that my cameras were disconnected from A/C power. hmmmmm! I tried what I thought was everything, and then it clicked. It was the app on my phone because I logged on from computer and all was normal. so I uninstalled the app and reinstalled it. works fine now. that's all it took. (glitch in app).
Anthony
Just bought refurbished system 10/6/2020. Worked fine for 1 week then
had the AC Power disconnect issue with Activity Zones off line. Never set up
the Zones in the first place. The PC worked fine. I just downloaded the Arlo android
app which was an update to the one I had earlier.Its the 2.21.2xxxx. And the app
is now working again. Will check it after a few hours to see if it still works. Fingers crossed.
Arlo Pro 2 no ac power warning problem solved with firmware update of Oct. 19 2020 and purchase and installation of new outdoor ac adapter for outdoor camera both camera battery packs are now 100 % charged and all features are working good.
