Night Vision Blurry Issue - Arlo Pro 2
Night vision blurry, not recognising facial features. See attached. Any settings I should be amending? Thx for assistance
Assuming the film has been removed from thge lens, I suspect this is light flare, perhaps from a nearby light hitting the lens.
yes... it appears the recording/picture is washed out from IR reflection off of a light colored wall/siding ... so
adjust camera.
As to facial features... the camera maxs out to about 25 ft for detection re the PIR and the IR illumination is a bit less due to the inverse sq law ( re lighting )... basicly not going to happen on a 200kb picture
I have skins on the camera to,shield the lens from nearby glare but will take another look at the position of the camera. The night time recordings in their current state are useless should I ever need to use any of them. Hmmmm.
