Need to change WiFi for my Pro 2 cameras and base station
  • 1 Reply
  • 3189 Views
g2jangle
I have 3 Arlo Pro 2 Cameras and Arlo Base station. I need to change the WiFi network. I have tried logging in to my.arlo.com and settings. I don't see any option to change the network. How do I change it.?
There is NO access to the wifi from the base as it is for cameras ONLY ( and arlo items )
Since the base plugs into your router any changes must be in your router.
If you mean the WIFI channel of the base, you can't change it... it will follow the same channel of your router ( if nearby ).
There is no access into the base unit.
You can change the router channel and the base will follow after a while.
  • 1 Reply
  • 3190 Views
