My base station VMB4000 is showing offline and camera LED is also solid amber
  • 1 Reply
  • 757 Views
dineshshukla
It appears that the base has been removed from your system hence the solid amber Camera LED. You can try claiming it again using the same process you used when first setting up the system, using the Add Device button in the Devices tab.
You may need to remove all devices in Settings, My Devices and start fresh. Claim the base and then sync the cameras, updating firmware as you go, if prompted.
  • 1 Reply
  • 758 Views
