My Arlo pro 2 has severe pixelation
Ok Arlo, this is an obvious problem that you need to correct before it starts to ruin your reputation! I can still trick the old app into working and this problem is not there, so clearly isn’t something you are doing with your firmware. This thing works worse that a camera 480i resolution. Pay your programmers and fix this! Customers shouldn’t have to tricks and gimmicks to have this thing work properly! Release a firmware that works or let us use the old versions.
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
