  • 6 Replies
  • 1099 Views
Bradrob1
Wondering if anyone has experienced the same problem as me?
My Arlo portal working all fine showing my 5 cameras for sometime now using two step verification, then overnight without any changes on my side, an issue where by the devices screen shows as follows.
Library & Mode are working OK but choosing a device in settings results in a blank screen. Can view all cameras on Arlo app on phone and iPad so don't think it is a camera sync with base station problem.
iMac running macOS Big Sur. Tried on MacBook Air running Big Sur. Same problem. Same issue on both Safari & Chrome. Have rebooted both base station & computer. Disconnected and reconnected ethernet etc.
Any thoughts?
6 REPLIES 6
Bradrob1
Sorry, an addendum to my message. Its seems the screen shot didn't load so I describe the devices screen as such.
A blank page except for a blank rectangle for one camera and a logo (no text- I think it is the add devices button) that when pressed sends me to an Arlo app page.
Thanks in advance.
ShayneS
Hi @Bradrob1
Are you still experiencing this issue with your web portal?
Bradrob1
Hi Shayne,
Yes, unfortunately I am.
ShayneS
I am not able to replicate this issue with safari or chrome. Can you try & clear your browsers cache and test again?
Bradrob1
Cleared both caches and rebooted. Unfortunately no Joy!
ShayneS
I see, thanks for the update. Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 6 Replies
  • 1100 Views
