Moving countries
  • 2 Replies
  • 1858 Views
SuzieL
Hi, Can I take an Arlo bought in the USA and use it in another country, ie. New Zealand?  Thanks
It should work with at least the Basic plan...unknown if higher levels are supported in the new country
https://kb.arlo.com/000062193/Why-can-t-I-sign-up-for-Arlo-Smart
https://kb.arlo.com/000062249/Where-is-Arlo-Smart-available
ShayneS
If purchased from a U.S. retailer, the power supply will be respective to the country. You may need an adapter for your country
  • 2 Replies
  • 1858 Views
