Motion record on one camera only. Tried on a different cam but switches to which one records.
  • 1 Reply
  • 838 Views
MCH1
Have used system for 6 months or so. New update now only one camera records at a time. They are both pointed at large parking lot when cars drive thru now it records one not the other. I’ve turned cam off then on but that switches which one records. I’ve got all my stuff set same as before. Little suspicious of the a entire new app means company split. Was about to buy 3 more cams but I’m hesitant now. Gonna see if it pans out. Any help far as not getting both clips just one cam or the other . Thanks !
Did you try restarting the base station?
  • 1 Reply
  • 839 Views
