Cam 1: pulling the battery did the trick!
Cam 2: good suggestions. I also may try to set up custom activity zones to omit the offending umbrella!
Thanks for your help!
For cam 1, I'd pull the battery to reset the camera and replace...test.
if no diff, then use remove device in settings and bring back with a sync.. Will need to change any custom settings as the will revert to defaults.
For cam2, the probable issue was the excessive recordings... As you noticed.
esp if the IR for night vision was on
easy thing is to also recharge the battery and it will reset if you pull the battery during change out.
For some locations and wind/ weather it may help to copy the current mode but lower the sense level and name it as " windy" .... Use it when weather acts up ( I have similar issue with a small tree )
