Local storage
Hello is it possible to use more than one cellphone/unit to view local storaged files?
I have WMB4540 Regards Ragnar
The locally stored files are only available from the main account (and only from the app, not the browser).
So you can access them from more than one phone/tablet if you use the primary account credentials on all devices. Unfortunately, Arlo only allows one login at a time. So when the second device logs in to see the recordings, the first device will be locked out.
This would be ok if you are just wanting to see the recordings on a tablet that isn't logged in very often. But if you are wanting to get notifications on both devices, it won't work, since you only get notifications when logged in.
