Local storage without subscription with Arlo pro 2
I am trying to have a local storage with the Arlo hub with usb connection.How do I configured it for local
storage without using a paid subscriptions.
please advice step by step process in using an external usb storage for capturing video from the Arlo cameras when it is triggered with movement.
thanks
rgds
adrian
Since you picked a Pro 2 camera you likely have a VMB3xxx or possibly a VMB4000. We need to know which one you have so look on the bottom of the base for the label that has that listed. The VMB3xxx have no ability to record to a USB drive while the 4000 does. However, the 4000 would require that you eject the drive for viewing on a computer.
How many unsubscribed cameras do you have? If five or fewer, then you should have the free 7-day cloud storage. Are you getting that?
