I have had my Arlo cameras for a month and love them. It now needs to be charged and the led lights on the charger do not light up and the batteries do not charge. I tried different wall plugs and plugged into a usb charger in the wall plug. No luck. Do you think the charger is bad?
James
The supplied charger ( ac adpter ) does not have LEDs... using the wrong one won't work
The two lights on top of the charger do not light up under any circumstances.
Are you using the charging cable and AC adapter that came with your Arlo system? Can you provide a screenshot of the charger you're using?
