Lag in recording start time. Motion sensitivity issue with 25 feet long but recorded 50%.
I have the Costco VSC3000 model of the Pro 2.
I'm at the verge of returning it, after giving it the lowest review possible everywhere I could.
My biggest gripe is the lag in recording start time. I know this has been addressed in other post with the cookie cutter answer regarding the FOV. Due to limitations at my front door I am stuck with my ability to get a very significant "profile FOV" (from the side). However when people come around the corner of the walkway, it's a pretty significant object coming into the FOV.
Even my driveway has the best FOV and is only about 25 feet long. Still as people are walking by they are only recorded once they are 50% through the FOV. Does motion sensitivity have any factor in this?
I honestly can't believe the horrible delay in lag is something that can't be fix by some feature of the settings. If it's truly a firmware issue with the design, I'm even more disappointed with Arlo.
Have you considered externally powering the cameras to take advantage of the 3 second look back feature?
Even with the 3 seconds of look back it wouldn't make a huge difference for the trouble.
A package was just delivered at my front door. My walkway is about 20 feet and the camera covers the whole length with as much side FOV I can get. If this was a guy "stealing" the package this system would have started recording and I'd capture his rear profile for 1 second before he turned the corner....disappointing
