- Email to a Friend
KB article for Charging Faults
The viewer gives me the message "A charging fault has been detected. Unplug and reconnect the charger from the camera side of the plug. If this error message persists, see KB article for Charging Faults."
I search for KB article for Charging Faults and get 5 pages of irrelevent responses.
1) Where can I find the article? - seems odd to but looking for an article in the help rather than a manual.
2) I've replaced batteries, cameras, charger, and cable, and the error persists, but only on 1 of the 5 cameras. - very odd.
Thank you if you know where I can find this article.
- Email to a Friend
Re: KB article for Charging Faults
I have the same issue. Quite frustrating.
- Email to a Friend
I don't quickly see aN article specifically on this but you might want to read through some of the FAQs here which may give you some insight. I would tend to suggest opening a case here as well since you've already run through many, if not all, of the troubleshooting steps.
- Email to a Friend
That link is broken! I too have had this message.
- Email to a Friend
Hi @TMProperties,
If clicking on the link doesn't work, scroll down and click on "Contact Support" as shown below.
Then scroll down again and click on "Contact Support". Feel free to let me know if you're still having problems accessing the support link.
- Email to a Friend
- Email to a Friend
Hmm, the link seems to be working fine for me. Try to clear your cache/cookies or try on a different browser to see if the link works.
