Issue With Arlo Pro 2 & 2 Base Stations
  • 1 Reply
  • 973 Views
SkipB
I purchase 2 Arlo Pro 2 systems with 3 cameras each.  The subscription is only allowing 5 cameras even though I purchased 6 cameras.  I want to hookup all 6 cameras using the same email address.  Is there a work around to fix this?
You can either upgrade your subscription, assuming your country has a plan that supports this, or set up a second account using a second email address. Remove one base and at least one camera from your first account and add them to the second one. Then use Settings, Grant Access from the second account to the first so all cameras will be seen in one login.
  • 1 Reply
  • 973 Views
