Is there any way of retrieving recording history for the month of August 2021?
  • 1 Reply
  • 821 Views
Skender
Hi,
Would there be any way of retrieving the recording history for August 2021?
I don't have a subscription anymore but need the recording for August 2021.
No.  It would have been deleted from the Arlo Cloud back in 2021 (7 - 60 days after it was made, depending on what subscription you had at the time).
If you have local storage connected to your hub, then you could connect the storage to a PC and check there.  But likely that would have been overwritten by now also.
  • 1 Reply
  • 822 Views
