Is there a way to tell the difference between Pro 2 vs Pro cameras
  • 2 Replies
  • 1137 Views
kraydad
I purchased some used Pro 2 cameras but one seems to have lesser image quality. How can I make sure I got all Pro 2 cameras? Is there a way to tell if one is a pro or pro 2
kraydad
Sorry, with a bright light and a magnifying glass I can see the camera in question is a pro 2. Seems to have a much lower image quality. But it says Pro 2...
kraydad
Not sure where you are looking, but the Arlo Pro 2 has a white ring around the front edge, where Arlo Pro has a black ring.
You can confirm the resolution by making a manual recording.  With Windows you then right-click on the recording and look on the details tab.  That will show you the height and width (in pixels) of the recording.
  • 2 Replies
  • 1138 Views
