Is it possible to create additional Schedule Modes?
  • 1 Reply
  • 2833 Views
northwesterly
I have "programmed" several modes for my Arlo Pro 2 cameras, and use them in conjunction with the Schedule Mode. I would like to create one or more additional schedules: one for when I'm at home, another for when I'm away from home, etc. Is it possible to create additional Schedule Modes?
The way it is now, you can only have really one schedule...but as you know you can use any mode you create in the schedule.
Only way for two schedules would be multi bases... there is no limit as to the number of bases on any level of service... and each base would have its own.  Works well if you can split the total cams into groups ( like inside / outside , etc )
  • 1 Reply
  • 2834 Views
