Is The 1080p Frame Rate Of The Pro 2 Better Than The Q & On Par With The Pro (720)?
  • 1 Reply
  • 1986 Views
shaolin95
Hello
So I just got the Arlo Q because I have seen some shots of it looking more detailed than other  cameras. Unfortunately I didnt know this came at the cost of very low frame rate. Basically during night shots, it looks sharper than the Pro 1 but as the subject moves it is always ghosting so much that it makes it pretty useless unless the subject holds for a moment for a clear shot.
The Pro 1 sure looks with less detail but the frame rate is higher so you get more options to pause the frame and get an image that is not fuzzy.
Is the Pro 2 like the Pro 1 but with the higher res or am I out of luck with these cameras?
Thanks!
ShayneS
Hi shaolin95,
We have an article with information that helps compare the different devices. The Pro 2 is 1080p with a larger field of view compared to the Arlo Pro, all this will help with achieving a better picture.
Which Arlo camera is right for me?
  • 1 Reply
  • 1987 Views
