I would like to assign 2 inside cameras to activate siren when motion is detected. How?
I have 6 cameras, 4 outside 2 inside. I would like the assign the 2 inside cameras to activate the siren when motion
is detected inside the house. Is there a way to to this, if so is there instructions on the website to follow.
Thanks in advance.
Yes. The way to do this is to create a custom mode that includes rules for each camera. You set the rule for each of the inside cameras to activate the siren after motion is detected.
You can edit the default ARMED mode to do the same thing, but it's better to create a custom mode and leave the default modes alone.
Generally if you want basic information it's a good idea to search the knowledge base - either using the search tool at the top of the forum page, or by using google search with site:kb.arlo.com.
Here are some relevant articles:
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
https://kb.arlo.com/1145394/How-do-I-create-a-mode-for-my-Arlo-Pro-Wire-Free-camera
https://kb.arlo.com/1145368/How-do-I-create-a-rule-that-includes-a-siren-trigger
