My Arlo Pro2 camera SN: A2R19877C6ADA
Recently, I updated the security Software to provide 2 level of authentication.
Pls help. Thanks.
Since this may be a hardware problem, use the Contact Support link at the bottom here to use your warranty.
We need all details. Does the camera's LED briefly flash blue when inserting the battery? What have you tried and what do you see? 2FA (2 factor authentication) has nothing to do with whether the camera is connected, it's just a login mechanism.
Problematic camera (Model: VMC4030P; SN: A2R19877C6ADA. Firmware 1.125.14.0_34_1189.). This my Add-on Camera (3rd camera), purchased several months ago. Base Station (VMB4000) was originally purchased with 2 Arlo Pro 2 cameras in 2018 and these (Base Station + 2 original cameras) are still working fine. I tried to synch the problematic camera with the Base Station many times without success. During Synch, the camera will initially blink blue & then later stay put at blue color.
Regards.
