I have 2 Arlo Systems. How to get notified for both systems?
I have 2 Arlo systems, one in the house and one in the summer cottage. The problem that the app only supports 1st system, I only get notifications and alarms from this, if I will get notifications from the other system, I have to log out and log in with another username. Can this problem be solved?, So I can be logged in on both systems at the same time?
First, you can solve the issue by upping your account level... the accounts are based on # of cameras not bases nor location of bases.
5 cameras is the amount for a basic level account ( free ) after that it becomes paid...which is the best way to do it for all cameras on one account.
( so you prob have more than 5 cameras and using 2 different accounts )
Or
You can share the 2nd account's cameras over to the first account ( grant access ).
this will allow you to see all the cameras on the first account and mostly have control of both sets.
