Hello all,
Need to change vidio length and other changes but on iMac no pencil to go to that section. I have pencils on iPhone and iPad but not on Mac.
The help tells me to sign in, well i do use the only E-mail and password i have and still no help. Yes i have reset base, deleted all base and cameras, still cant get to the pencils in Mode.
Any help ???
We wanted to let everyone know that our development team was able to resolve the issue where you can see the edit button now through the Mode Settings on Safari and Microsoft Edge.
Why isn't mode working on my computer. I cant change anything
My base unit keeps saying no internet connection when it says offline constantly
No it is not the base station.
I can't get into mode using the computer to change the way the camera works.
I assume your using Edge or Chrome as your browser...........Looks like Arlo "updated" the website and now they have intruduced another bug for Edge. You can no longer edit a mode using edge. In chrome the arrows that you normally click to edit a mode may be missing, but if they are just click in that area and you can edit the mode in chrome. Hopefully Arlo fixes their website so it works with Edge again.
jeross,
What device and firmware are you experiencing the issue with? Do you have a screenshot of this?
Here you go........ you can see there are no arrows on the right of the mode where you'd click to edit the mode. Clicking the mode anywhere on the line only changes modes, you can't edit the mode in edge anymore. Screen shot attached...
So why have you screwed up something that wasn't broken?
jeross,
Do you have the edit option functioning with Google Chrome?
I don't have google chrome.
cheers
Jane
I can confirm that you can edit a mode in Chrome. You cannot edit in Edge. (also still can't play library videos in Edge)
Devs need to fix the site to work with recent MS updates and Edge please.
I can't edit on Safari either. I noticed this yesterday.
2017 Macbook Pro running Mojave
Maybe try a diffrent web browser or contact support.
Support Center
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
Did try support, waiting to here frome Level @2.
Also just tried on Explorer and same issue as Safari no pencils but have them on iPad and iPhone
ok ya it may just be an html programming issue on Arlos site with Mac and or Safari. I do not own a Mac so I can't be of more help.
Thank you for your reply, just FYI it did not work on Explorer either.
can you do any settings or just view stuff ?
Well if i go to settings i can do the basic, rotate image, night vision but thats it. In mode no pencil like i get if i use my iPad or iPhone.
Thank You!!
OK I see an issue, in Windows Edge I can not edit the Modes, but In chrome I can edit the Modes. Note the Edit link on the right site.
Microsoft Edge 44.17763.1.0
Chrome Version 72.0.3592.0 (Official Build) canary (64-bit)
clearly they have cross platform programming html issues.
Well I have a iMac that runs Safari and my iPad the same, i can edit Mode on iPad but not iMac. It worked before i did a hard reset on base and even deactivated all 3 cameras and then reinstalled them. i saw that i need to sign in as as the ad men well is sign in on both with the same user and password????
Yes use the primary account to Login.
Note: you can only be loged in on 1 device at a time per account.
When you setup a Shared account there is an option for Granting Access.
Thanks Again
I only have the one login eMail and password and i use it on all devices, iMac, iPhone and iPad.
On the iPad and iPhone i can get to mode then Pencils same sign in on iMac no go for Mode then Pencils.
Yes i know i can only be loged on one device it will kick me of one if i logon with another.
Thganks!!!
Yup.. Using Safari, no edit on mode..
						Arlo Mobile App629
						Arlo Pro 211
						Arlo Smart180
						Before You Buy995
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,322
